Danger Dog
Do you have to jet differently if you premix and do away with oil pump? Stock SRX.
YAMMIEGOD3:16
HELL OF A GOOD QUESTION. I WOULD ASK WHAT OIL RATIO YOU GONNA RUN ? 3:16 (yammie tony)
Danger Dog
40:1 I would think it might be different seeing that yamaha injects oil in the fuel pump.
OZ_872
why are you switching it to premix? just curious. I don't think you would have to rejet anything because the oil and fuel are mixed in the fuel pump like you said. so its going through the carbs as a mix already.
valin
Do not rejet.
srxbully
dont rejet as stated already but i'll add dont i wouldnt take the pump off niether.just why?
Danger Dog
I am taking the pump off because it is just used for drag racing. I don't like to rely on a pump for oil. And I am turning the oil tank into a fuel tank 3 quarts, so I don't have to lug around 3-4 gallons of gas. Extra weight!
srxbully
most stock sleds are suppost to keep there oil tank & pump.
OZ_872
Danger Dog said:I am taking the pump off because it is just used for drag racing. I don't like to rely on a pump for oil. And I am turning the oil tank into a fuel tank 3 quarts, so I don't have to lug around 3-4 gallons of gas. Extra weight!
Great Idea, maybe they'll let you run stock if you leave the pump on yet?
Danger Dog
srxbully where I run tech is not that critical.
