srx600 to a 700
YA*AM*A*HEAD
indiana
hey guys i am thinking of changing one of my 600 to a 700 ...what do i have to get from the 700 to put it in my 600 ..wire harness? cdi? carbs .pipes ? anyone done this ? how hard will it be thanks
The only similarity is the bottom end (cases & crank) & pipes. The carbs can be changed over but the parts will be $$$. Your better off to selll your 600 & buy a 700.
you can use the carbs, 33 on 600 and 700 only need to change the jets and "jetpipes" ?? dont know what its called..
the harness is okey, you get more timing but thats no problem!
the base of the 600 is the same as 700 only change cyl and heads, pipes are ok!
had a 01 700 motor in my 99 600 and it ran awsome!! but i didnt run the 3d 00-02 harness so i lost 3-4 hp.. my had the same ca 140 as the stock 98-99 700, but for some reson , maybe timing? was faster:) its sheap and easy build! go for it! but have it hit max rpm at 8400 -8500, to mutch rpm is not good with more timing..
