harness racer
What cdi box would i use if i converted my 600 ?
i got the cases ,the mag + flywheel +the harness + the coils all off a 700-01
will this work or not , ???
thanx vince
thanx vince
srxbully
01 or 02 cdi.
the srx600 cdi box uses a bit more timing then the 700 does, I would think youll need to make a timing key using a 700 box to keep the performance good on the 600. Your conversion will work if you use all the parts, wiring harness,cdi box, carb rack with tps, flywheel,cases,stator.
