snowprophet1
I got the bug and had to go 780 big bore too! For those who are running this setup, is anybody running their yamaha heads cut for the big bore, or has everyone used the aftermarket better cooling heads? I really want it to look stock, so I'd like to use the srx heads on it. Just wondered if you can ride trails all the time w/no overheating problems or seizures. THANKS!
NY_SXR700
If it's Jeff's 780 kit. It looks stock because it uses the blue SRX heads cut the way he wants them. I have only seen one but I see it all the time. If you did not tell me I would never know. As long as you stay with stock carbs by letting Jeff bore them no one will know. Except when you rocket out of the hole and wax the T-cats, F-7's, Poo's, and anything else that thinks it has the nads to run with a stock SRX. Doug
