Motor Mounts and Motor
SXlover
Minot, ND
Anyone ever seen any busted motor mounts on a Viper? Is this a problem in the 02's at all? And is it possible to put a red head motor into a Viper chassis?
I broke 3 sets on my 02 ER model. The cure for this in your case ids the stronger SRX mount AND adding a torque stop. I couldn't use the SRX mount because of the electric start. That being said, I never broke another mount after I installed the torque stop. Easy instal on the stop, motormounts are a BEAR LOL!
Yes it is possible to put a red head in a viper chassis. I'm doing it right now. Had to make a motor mount for the front mag side though. the rest were viper motor mounts bolted on. As for broken motor mounts use a torque limiter. Also tripple pipes will fit right in.
