a little question
Carioca_Jr
Lindsay ON
I've always wondered what a modded head (780) and a single pipe would be like, or would it even be worth it? i may consider it.
are you talking a stock head, that has the dome diameter modded from stock diameter to the 780 bore diameter? you dont want to run a head modded for a 780 kit, on a stock bore motor. do you have a 780 kit now? if so, why would you want it to try and breath through 1 pipe?
I don't have it, but i know of a really good deal for one. and yes i am talking about the 780 bore.
But why wouldn't i want to do it?
why wouldn't you want to do the big bore? no, do that...as that's a good mod, but you had originally asked if you should run a 780 modded head and your single pipe. that's what i was saying no to. yeah, you can big bore your sled by all means. whos kit are you looking at and how much? what's all included?
It was just going to be the 780 bore head, gaskets ect. no pipes or anything. I just wanted to be the one with a single pipe, with about 140 horsepower + but i doubt that will happen anytime soon.
He wants a 780 big bore with the stock single pipe.I'm shure it would work but there might be a heat issue with the stock pipe and stock cdi box.
i think he wants to just use the head.(leave clyinders alone) *use the stock pipe?? maybe he means milled head?? ordid they make a special head for a 780 bigbore??
I would get the cyls done, i forgot to mention that before. But what about that bender 4x4? if that would do anything for helping with the cooling if i was to get that done?
the single pipe is just a bad idea. why big bore, if you are only going to try and make it breath through a single pipe? look at how much power you get from just adding pipes to stock viper. seriously, triple pipe that thing. don't mess with the bender 4x4 pipe either. maybe, you should just leave it stock?
Its just i don't feel like spending more money, and more money, just to be spending MORE on gas.. ill just keep her stock. to many miles on it to pipe it right now.
