What's it worth?
SXlover
Minot, ND
I have a chance to buy a 2002 Viper. It has Tracks USA tunnel and rail extensions to 144", holtzman variflow, fabcraft mountain bar, lefty throttle, running board grips, dynoport can, ice scraters, handlebar risers, and a drilled 2" paddle track.
Now for the bad. Don't know how many miles are on it, it has a busted motor mount, and only 95-95-85 psi from mag to pto side so something isn't right with the motor.
Depending on the miles and if it looks to be in good shape other than the engine I wouldn't give more than about $1500 for it TOPS.
You need to take the time to part it out. Running Vipers are selling for $2000. From the compression on that one I would say it is on its way out.
$1000 IMO. (It is June!) ;)!
