Jay1823
I bought a 91 Exciter 570 sled engine for my single seat dune buggy but when i receive dit the guy had taken virtually everything apart. I bought a manual but it doesn't have nearly any hose routing info. Right now my to biggest concerns are the oil pump hose routings and part of the carbs routing. I MS paint'd the photos to make it a little easier to convey my questions.
On the oil pump there are 2 large ports and 2 small ports. I'm guessing 2 are the outlets to the carbs i believe. Now are the other 2 a feed / return setup or are the both feed ports. I threw numbers by them so maybe someone can tell me #1 goes here, #2 goes there, yadda yadda.
As for the carbs i'm guessing the 2 connections with the black hoses are for coolant lines, i won't need those if that's the case. This buggy will see limited cold weather use. Now i'm guessing the 2 white ports on either side are for the oil lines. Now are they both inlets or a feed / return setup.
Any help on this would be greatly appreciated. Thanks Jay
