Installation of Srx pipes
Yamidude59
Jackson Wi
got my pipes back from the coater, Got all my new gaskets, i have the manifolds on etc... I want to know the order in which the pipes go in? i obviously put the muffler in first, but do i bolt it down right away or do i have to get all the pipes in before tightening it down? Do i start with the mag side pipe or the Pto side or middle? and then where do i go from there?
Thanks for any help.
Joe
The way I do it is put the muffler in loose, then take all three pipes at the same time by wrapping your arms around them and setting them in roughly where they should go. Makes things easier and takes almost half the time of setting them in one by one.
thanks Yammiegod, That way worked the best... Change up..., it took me about 5 minutes to get them in the normal way, Plus its way easier to get the springs on each pipe when their in there one by one, would rather not have the pipes bang togather because the Ceramic coating won't be cured till winter when i can start it up and let them Heat up. Thanks for the Help!
