I'm hoping to get a watertemp gauge installed on my 01 MM. I want a type that I can attach to the coolant hose, using an adapter.
This is the gauge I want to install:
A cyberdyne A020E360N (black bezel)
http://www.horsepowerfreaks.com/partdetails/Cyberdyne/Gauges/Water_Temp_Gauges/Blue/10445
Now for the part that makes you
The gauge needs to show Celcius and not fahrenheit.
The adapter needs to fit a MM coolant hose which I believe has an inside diameter of 1 inch. I haven't found an adapter with this inside diameter yet.
The gauge will only work with this sender
http://www.jegs.com/i/Cyberdyne/280/SENSS6E/10002/-1
and the gauge needs a wiring kit. Where can I find the parts I need?
thanks
thanks
How about similar autometer unit with metric scale?
Yes I'm open for that too, I just can't find the things I need to make it work. Finding the adapter seems to be the worst bit. Do you know any finnish auto shops where I could get a 25 mm adapter?
What thread size it needs to have?
Gjengene 1/8"–27NPT threads if that helps.
Or
Sensor has 1/8" NPT thread.
Or
LIITOSKPL, LÄMPÖMITTARI 1/8NPTF 26MM:N LETKULLE PUNAINEN
I found from here 12€. Red adapter for 26mm hose.
Great, whats the adress?
There was no picture available but it's finnish site www.moposport.fi
http://www.moposport.fi:8080/worksp...dService?file=page&pageID=9&itemcode=59551109
Autometer parts
http://www.autometer.com/cat_accessoriesdetail.aspx?vid=51
Thanks, but no picture? no purchase... Still nothing useable really..
I found the adapter at least:
http://www.slp.cc/catalog.cfm?pageID=detail&catalogID=5&catID=40&productID=512
