nailsandrails
I thought someone told me that Arctic Cat had a cable drive to the electric start motor on some model. Anyone know if it's true? I was thinking that could be an option for adding electric start to an SRX with some fabrication although I haven't seen the cable drive version if there is such a thing.
yea i thought you couldnt put an elec. start on the srx or at leaste thats what i was told?
nailsandrails
No you can't with a kit or anything. I was looking at other options as a way to get it on there. Room is limited.
I have seen an SRX with electric start, I know it can be done but i never found out what the kit was from sorry.
you can put a stadard electric start on a srx. you will need to mount the battery in front of the left shock, use a viper motor mount or modify yours, all the cables and wires end up being shorter and longer. I have a basic kit with everything you need for 225 shipped. ring gear, starter, solinoid, wires(they will need to be modified)you will need to remake the battery box or use a different battery and make your own box. some of the light weight ones for the rx1/apexes are very small and alot lighter. the stock size ones will fit though.
BETHEVIPER said:you can put a stadard electric start on a srx. you will need to mount the battery in front of the left shock, use a viper motor mount or modify yours, all the cables and wires end up being shorter and longer. I have a basic kit with everything you need for 225 shipped. ring gear, starter, solinoid, wires(they will need to be modified)you will need to remake the battery box or use a different battery and make your own box. some of the light weight ones for the rx1/apexes are very small and alot lighter. the stock size ones will fit though.
Does that kit fit the 02 viper as well?
