Which Track?
camo 9830 is a 1", originally designed for snox. On my 500, the track hooks as good on hard pack, as studs do on ice! It's a 3rd window closed design, which cuts down on slide wear too. You can run 1.25" Extreme max studs with this track, as long as you've got the protectors in there.
Good luck!
