pup55
Need some info on installing a rear heat exchange in a 03 viper. It looks pretty simple but I want to make sure I do it right. I know how to put the heat exchange in but my question is on how to bleed it. Should I drain the hole system or could I raise the rear of the sled and just let the antifreeze in the rear come out, then add new antifreeze and bleed.
Pup raise the rear up remove the H/E bleed bolt fill the system till any air is
gone replace the bolt,,top off coolant in the bottle to proper level,loosen the bleed bolt on the coolant rail(by the carb heater on/off valve)drain the coolant till no more air is seen..
idle sled till warm making sure bottle stays full..
pup55
Thanks daman
