Will this fit....
Will it fit in what. If you are asking about your sxr then the answer is sort of. It's not a bolt in as the added length is in the middle of the rail not on the end like an extended 121 skid. The front mounts in the same holes, but the middle and rear will require new mounting holes.
Ok thats what I thought, sorry about the messed up typing. Our computers are work are slower than piss so typing is a pain.....
Now I guess I will be getting some rail extentions....
you will need to place a reinforcement tward the rear, i may have them, if not you can just make some. the rear arm mounts about 7inches back. if you go this way, i can give you the measurements.
the cb performance drop brakets would work perfect for it. I have a stock set but saving them for my 136 skid when it sells. Maxdlx
Would a skid out of a Venture work better? As far as not have to re-drill holes and whatnot... also there is a member on here with a Venture skid on his SX I think anyone think who it is??
