marty f
will a 1.25 predator six pitch fit right in my stock srx or will it rub? i do not have protecters on the front heat exchanger
It will not rub on the front exchanger. As for the tunnel ones I don't know. If you stud it then I think you'll need to swap to 8 tooth drivers. A 1.75" track will clear with all the protectors out and the stock 9's in place.
it will fit without studs, if you stud it you are asking for trouble. Maxdlx
