Rear idler wheels...
Coles_55
Eagle, WI
Does anyone now the size of the rear idler wheels?
I was looking to put a set of 7.25" wheels with 1.5" id bearing on my sled. Will it work or no??
you can go to 7.5 inch wheels from an old sled like the enticer exciter and you will be able to use the stock rear axle. Im not too sure on the bearing size but I think the older ones might be bigger which is good.
