hey there guy.i read your post on tighten up pro action and understand most of it,however i could really use some additional photos.do you know anyone that has any?the other question i have is does the coffe can material thats put into the bushing wear the plastic bushing any faster.thanks
i dont have any pictures. the material goes on the outside of the bushing, not on the inside where the collar turns. it makes the bushing last longer as you can keep grease in the bushing. loose collars in the bushings will beat back and forth and smash the grease out. loose collars also allow water to get in and cause rust, this causes the bushings to be eaten away by the rusty collars.
