SRX 700 Grassdrag jetting
Adde
Finland
There is a local grass-dragrace in a few weeks that I´m gonna participate in,
however I´ve never tried running the sled in warmer conditions before.
I searched around a little on jetting and saw a recommendation on 135 Mainjets with 47.5 Pilot jets. It´s getting a bit colder here now, about 10 degrees celcius, (50 degrees Fahrenheit) so I was wondering is it still safe to run those jets? It´s at sealevel..
Or should I go up to say 137.5 MJ and 45 PJ to be safe?
The sled is a -01, with stock motor.
/Adde
137.5 mains will be fine, your not on the main jet but for about 150-200 ft in a 500 foot race anyway, hard to blow em up in a short race. Youll need bigger pilots to keep the engine from stumbling on take off. Pilot jets- the 45's will work but the 47.5 will be better if you have a aggressive clutch set up. What do you have for clutching??
Do alot of work to the suspension, thats where alot of gains are to be had with a srx on grass.
hmmmmmm ...such as?
It's a 500 feet distance. I haven´t done much with the clutching yet other than the "common" setup from this forum. So I guess that is more of a allround trail-setup..
WWW primary, 2x 4.5g, 51/43 Helix and either red or green secondary spring.
Gearing is at 22/38 at the moment, wich I guess is too high for a dragrace.
I have replaced the 6 stock idler-wheels with the oversize Polaris ones. And I have one "marginal snow" wheel kit up front in the skid, near the bumpstop.
Combine that with a pair of worn out hyfax:es the track spins quite freely.
I´m a bit unsure how to get the supsension tied down correctly. We start on "traction mats" (25 feet long distance of upside down snowmobile tracks).
So if I get too much weight transfer I will get a bad wheelie from the start, wich looks cool but it´s slow.
I read through your post mrviper on the thread below. So that seems to be a good starting point.
http://www.totallyamaha.net/forums/showthread.php?t=27044
I once tried the following: Taking both stock shims on the transfer rods and putting them on the top position. Then I made a larger shim to fill the remaining gap on the bottom. There was no gap at all left on the transfer rods. Then I tied up the limiter straps quite a bit to get the track to sit more flat to the ground. This gave me some strange wheelies from the start tho... Perhaps I need to pull up the limiterstraps even more...
/Adde
follow that thread you posted on suspension set up and youll need some more aggressive weights for drag racing and a bit steeper gears. If you want a cheapo clutch kit use a set of 8bu-00 weights /4.5 rivet tip only with a grn/wht/grn spring, use your same helix and grn sec spring.
H/c's will give you the best times. For gearing a set of 21/40 would be ideal. :EXER:
Thanks alot indeed for the quick answers!
I have the jets ordered, and I can get my hands on 20/38 gearing for starters.
Now I just need to get some practice time to get the suspension sorted.
/Adde
