I just finished bleeding my coolant system on my viper after installing a SRX rear heat exchanger and an opti-cool head gasket,I open up the bleeder in the rear and the coolant shoots out,i also removed the top and bottom srews that hold the carb heater on and off valve in the head and pulled the valve out some and coolant started to run out the bottom hole.Am i finished bleeding the system or is it possible that there could be air trapped in it still.Also all the exchangers get warm after letting it idle for a while.
bleeding
Sounds you did a good job to me. You should be ready to go.
taylzee
It's not a bad idea to do this procedure another time or 2. I have had air get trapped in the system and create minor problems on the trail.
Mighty
Cycle it through another time or two. Elevate the front of the sled with a floor jack and while the front is elevated rock the sled from side to side with the cap off and sled idling. You will be surprised how much more air will bubble out.
