Apex to SRX bars....
Roost 'Er
Flamborough, ontario
Have a line on a set of apex bars and warmers what ever i need, but i need to know what i need haha.... anyone who has done it have a list of things i need to do this conversion?
you will need a throttle block from a 04 viper, throttle cable, and about a 2in riser to make back the distance.
you can make a set cheaper out of yours and you wont need the throttle block, cable or risor.
you can buy stick on eliments for about 15, hooks for 35 a set(get plastic ones) and grip covers from yamaha for under 20 a set. they will heat better than the factory ones your trying. i have used them and made several sets and never had any issues with the cheap eliments. best part is you can turn the hooks where you want them.
below is a picture of the last set i made, these have cat sly grips on them as yamaha was out of stock at the time.
Thanks betheviper as usual, my other question is i can get the apex bars complete, cant i just wire the warmers factory on the 2006 apex to my wiring harness..?
