SRX Bogging during longish Ride
paulthewallt
Winnipeg
I have a 99 SRX 700. The problem is, after riding for a fairly long time at trail speeds, if I let of the throttle to slow down and the engine starts bogging down and can't accelerate until I let it hit idle for a few seconds. It's annoying, sounds terrible and is dangerous. Once it catches, it's good to go again. This is the only issue. Everything else runs great.
Any suggestions? I really need your help!
P
you can bypass that switch to test it. Just follow the wires till you get to the bullet connectors. unplug them and then take the 2 from the wire harness and plug them into each other,like making a loop.if your problem goes away,its your T.O.R.S. Adjust throttle cable or idle as needed
