Clutch set up
yamaracer18
marcy, ny
Looking for a bad a$$ clutch set up for my 02 viper, i have simons cpr pipes, vforce 3 reeds and simmons cpr modded head, looking for the best trai/drag set up i can get thanks
Just a heads up. Those are 2 completely different set ups. A good drag set up would not work well on the trail & vice versa.
Yes one or the other. You cannot get 2 things at once down with clutching and have to clutch your sled for the riding you do 90% of the time.
Im sure Turk can provide you with an excellet aggressive trail set-up
ok then i guess i looking for and aggresive trail set up then just something to rally spank my buddies 2001 xcsp 600 wit some work done like pipes and bigger carbs i know i can take him no prob but my sled wasn't running right last year think my cluch is dust seized and the springs are whipped
How many miles on the sled? Might be due for a new ring job..
Take your clutch off and inspect the rollers, weights and spring. I have to ask but how worn is the belt?
how are the power valves....dirty and/or pulled through? how are the bushings in the clutches....worn out?
