I have an 03 Viper. I think my front heat exchanger may have a leak. I wanted to know the easiest way to remove it to have it repaired. I was wondering if the driver shaft has to be removed? Any suggestions would be appreciated.
If You can see pick damage try using some jv weld it is a two part expoxy. Grind or clean up the area and glue it up.Any way you do it the track has to come out.
