Doo rear skid springs
fourbarrel
VIP Lifetime Member
I am going to put a heavier set of springs in my SC10 II and wondered if there was a chart in existence somewhere to get some part #'s from.I looked at a couple of online microfiche sites but the only #'s listed were for the standard ones even in the pages for the X sleds which would have the heavy springs.I noticed a set of 3 green paint marks on one of the springs from my skid and wondered if Doo used this method to mark the springs the same way clutch springs are designated.Anyone have any info?
Go on dootalk and do a search. Also Send a pm to IANSMXZ. You will have anwsers within the day.
If you own a doo skid, you should be a member on dootalk just because any help/questions/input you have will be about skidoo and thats all the site is.
I'm changing the skid on my SRX also and the SC-10 II is one of my options. Are you changing the springs because the original one are fading?
The original springs are probably a bit weak from use but they were never heavy enough to start with for my weight.It seems that unless you weigh 160 to 180lbs none of the factory calibrations are set up for those of us with more AHEM girth.
