Bender 835 pipes
i run them on my mrviper built 700, bored carbs,v-force 2, lake race ported base and cylinders, cylinders ported to work with the big bore pipes,they do work, i noticed a big difference mid to top end, plus you loose 10-15 pounds over stock pipes.
I ran them on a 700 stock motor and a 700 trail ported motor. I always went faster with the stock pipes. The stock pipes flow more than enough for up to about 175hp applications. After that, more RPM is needed, and different pipes are required. I did not try running the 835 pipes on any of my 780's. My advice......save your money and keep the stock pipes.
