P/N for transfer rod spacer
nailsandrails
Northern, IL
97 XTC 500 that has transfer rods.. The thin spacer at the bottom is missing. Anyone know the P/N for it? The fiche doesn't say what the thickness is so I can't figure out which one I should order. Thanks!!
xtc 500 lower spacer should be 2.5mm, yamaha pt # 90202-16229-00. measure the other side and make sure. if its a different thickness, let me know and i will give you the part #.
