Nos
blackford81
Edmonton
I ride a 2000 mm700 with psi pipes and stingers, v force reeds, 156 ekholm skid, ekholm tunnel, ekholm trailingarms, 6" risers. i was looking at putting nos on and wanted to know what your thoughts are on it . does it work good and how reliable is it. do you have to rejet for it.
Nitrous is a great add on, But its short lived due to the size of the bottle.
Thats why its usually only used in racing applications, short distances.
Not very practical for trail, or boondocking riding.
generally you run a wet system which injects fuel and nitrous, requiring a battery and a seperate fuel pump ect to run the solenoids and pump.
It can be done reliably and safely, when done right. Thats the key.
I have a fogger kit on my srx700 and it seems to work ok it has 35hp nozzels in it. It is fogged in to the airbox and runs off vaccum in the carb bowls to trick them to push more fuel in. It isn't the best system out there but it works, the system is from boondocker. I got it off an other TY member. It was easy to install no batteries needed.
