tjsands12
just bought a 2002 viper, i want to add some performance to the sled. i was thinking about a can, reeds, and some clutching. my track has 144 studs. not sure of what to go with on any of these. any feedback is appreciated!!
1.)clutching-Excellant investment, something youll more then feel when you ride the sled
2.)can-waste of money, they just make noise, youll never ever notice a 5lb weight loss on a sled
3.)reeds- another waste of money unless your modding the motor
4.) other areas where you get a good gain to money spent is oversize idler wheels, better track, setting up the suspension/ tuning the carbs,clutch's, powervalve settings, all will make the sled run alot better!
blueblooded
I ran a set of heel clickers on mine.It really woke the sled up.
tjsands12
what can you do with the power valves??
Make sure they are clean and adjusted.
OZ_872
depending on how many bennies you have laying around the first thing I would mod in order to acheive higher horsepower is throwing on a set of triple pipes and the clutching to match. you may have to add the extra heat exchanger or the cooler head gasket but those are good things to do regardless.
