ss racing
I have a 98 SRX, and I'm changing all the black plastics to Blue. I have everything but the front bumper and Gauge Pod. The problem is my black gauge pod part # is 8DF-77251-00 and on my wife’s 00 SXR it has a single bulb BLUE gauge pod and its part # is 8DF-77251-00. So how do I figure out the part number for a BLUE single bulb gauge pod?
what your missing is the next to the last digits, this determines the color, the blue one you want would be part number-8df-77251-10-00.
the black one you already have is part number 8df-77251-01-00
ss racing
mrviper700 said:what your missing is the next to the last digits, this determines the color, the blue one you want would be part number-8df-77251-10-00.
Both of them are the same, neither one have a 01 or 10 and it doen't appear that the numbers got rubbed off. Thanks for this info because now I know what I need, but why would they not have stamped it that way?
well, I am looking at the microfiche, not the parts but those parts numbers I gave you will be correct.
ss racing
Thank you, I really appreciate the help. I couldn't figure out the part numbers when I looked them up. Then I decided to see if they had different part number issues for other sleds. So I looked up a 2000 SRX(blue), 2001 SRX(black) and a 2002 SRX(black) and all three were different. I thought that was odd because there should only be two different numbers, one for black and one for blue. But then I remembered that the 02 would have the hole cut out for the DCS thus making the third number change. I can't figure them out some times, thanks for the help.
