I need to know the drive shaft size on a 96 Phazer so I can order my 7 tooth extro's...sled is in storage!
Yamidude59
yamaha dealer can tell you anything you want to know, if you go in and ask the right person who has the diagram.
PZ 1
- Mar 12, 2005
I don't know of Yamaha having any kind of a diagram that would give that info.
The shaft size is about 1.064 or 1-1/16 inch. You will have to do the math if you need a metric number.
Thanks PZ1. I wonder if 7 tooth anti ratchet drivers will work? Wahl bros does make them....but I have regular 7 tooth drivers in it now and it appears the anti ones would hit the rails. Kind of an expensive lesson. Anyone tried it?
Just trim the rail tips and and an anti stab wheel kit. Problem solved.
