Tool definitions
crewchief47
Lifetime Member
Windsor, ON CAN
Website
sledtoyz.com
I'm sure alot of us have seen this, but it is still good for a laugh now and again:
TOOL DEFINITIONS:
DRILL PRESS: A tall upright machine useful for suddenly
snatching flat metal bar stock out of your hands so that it
smacks you in the chest and flings your beer across the
room, denting the freshly-painted part which you had
carefully set in the corner where nothing could get to it.
WIRE WHEEL: Cleans paint off bolts and then throws them
somewhere under the workbench with the speed of light. Also
removes fingerprints and hard-earned calluses from fingers
in about the time it takes you to say, ''What the...??''
ELECTRIC HAND DRILL: Normally used for spinning pop rivets
in their holes until you die of old age.
SKILL SAW: A portable cutting tool used to make studs too
short.
PLIERS: Used to round off bolt heads. Sometimes used in the
creation of blood-blisters.
BELT SANDER: An electric sanding tool commonly used to
convert minor touch-up jobs into major refinishing jobs.
HACKSAW: One of a family of cutting tools built on the Ouija
board principle. It transforms human energy into a crooked,
unpredictable motion, and the more you attempt to influence
its course, the more dismal your future becomes.
VISE-GRIPS: Generally used after pliers to completely round
off bolt heads. If nothing else is available, they can also
be used to transfer intense welding heat to the palm of
your hand.
WELDING GLOVES: Heavy duty leather gloves used to prolong
the conduction of intense welding heat to the palm of your
hand.
OXYACETYLENE TORCH: Used almost entirely for lighting
various flammable objects in your shop on fire. Also handy
for igniting the grease inside the wheel hub you want the
bearing race out of.
TABLE SAW: A large stationary power tool commonly used to
launch wood projectiles for testing wall integrity.
HYDRAULIC FLOOR JACK: Used for lowering an automobile to the
ground after you have installed your new brake shoes,
trapping the jack handle firmly under the bumper.
EIGHT-FOOT LONG YELLOW PINE 2X4: Used for levering an
automobile upward off of a trapped hydraulic jack handle.
E-Z OUT BOLT AND STUD EXTRACTOR: A tool ten times harder
than any known drill bit that snaps neatly off in bolt
holes thereby ending any possible future use.
BAND SAW: A large stationary power saw primarily used by
most shops to cut good aluminum sheet into smaller pieces
that more easily fit into the trash can after you cut on
the inside of the line instead of the outside edge.
TWO-TON ENGINE HOIST: A tool for testing the maximum tensile
strength of everything you forgot to disconnect.
CRAFTSMAN 1/2 x 24-INCH SCREWDRIVER: A very large pry bar
that inexplicably has an accurately machined screwdriver
tip on the end opposite the handle.
AVIATION METAL SNIPS: See hacksaw.
PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals
under lids and for opening old-style paper-and-tin oil cans
and splashing oil on your shirt; but can also be used, as
the name implies, to strip out Phillips screw heads.
STRAIGHT SCREWDRIVER: A tool for opening paint cans.
Sometimes used to convert common slotted screws into
non-removable screws.
PRY BAR: A tool used to crumple the metal surrounding that
clip or bracket you needed to remove in order to replace a
50 cent part.
HOSE CUTTER: A tool used to make hoses too short.
HAMMER: Originally employed as a weapon of war, the hammer
nowadays is used as a kind of divining rod to locate the
most expensive parts adjacent the object we are trying to
hit.
MECHANIC''S KNIFE: Used to open and slice through the
contents of cardboard cartons delivered to your front door;
works particularly well on contents such as seats, vinyl
records, liquids in plastic bottles, collector magazines,
refund checks, and rubber or plastic parts. Especially
useful for slicing work clothes, but only while wearing
them.
DAMMIT TOOL: Any handy tool that you grab and throw across
the garage while yelling ''DAMMIT'' at the top of your
lungs. It is also, most often, the next tool that you will
need
oh my god!!! sitting on the couch reading this to myself, then bust out laughing out loud! my wife (sitting next to me) jumps and screamed and Im pretty sure the dog pissed on the carpet!
