mikerx
I just bought an 03 Viper. I went out and bought a compression tester and got readings of 130-135 psi on the 2 cylinders and barely 120 psi on the clutch side cylinder. I warmed it up a little with no improvement. The sled shows 2700 kms on it. Is this major?? Will I be ok for this season or do I need some work done?? Any help would be great!!
Thanks,
Mike
Thanks,
Mike
mopar1rules
you have nothing to worry about. that pto (clutch side) has a larger cc dome volume for the head, so it will read less psi than the other 2 cylinders.
SRX7
Vipers came with a lower compression piston / head assembly on the #1 cylinder. This was to allow for straight - across jetting on the triple carbs. (If you noticed, all main and pilot jets are the same for all three carbs). It's normal for the #1 cylinder to have lower compression. According to yamaha documents, the compression ratio on the #1 cylinder is 5.9:1, while #2 & 3 are 6.7:1. Hope this helps...
mikerx
Wow!! Thats almost 15 psi!! I know with my old RX-1 it had to be pretty close on all 4 or you were looking at trouble so I figured it was the same with the Viper.
