transfer rods
scootersrx7
fort mcmurray alberta
hi
i am trying to figure out where long travel transfer rods are longer,
can someone measure from the washer that is welded on their transfer rod to the top of their transfer rod
thanx
ps i think i was able to attach a pic of the measurements i need
they must be different than my srx rods because the part nombers are different
thanx
hope this helps
I will only post first part of part #s cause it is the only difference
8ac 310.5mm from center of eye to end, and 195mm from washer to eye center.
8cr 310.5mm frome eye center to end, and 200mm from washer to eye center
8ed 262.5 mm eye center to end and 146 mm washer to eye center. What year srx do you have. I have a stock set of long transfer rods I'll make you one hell of a deal on. maxdlx
hi
i looked up the part numbers and i have the 8ed transfer rods,
the reason i noticed that i needed longer rods is that after i put in my viper shocks and tightened the bolt on my rods the suspension sucked down 3",pretty much losing any long travel i was trying to gain
let me know how much for your rods and are they 8ac or 8cr?
thanx
