Gas life...
Yamidude59
Jackson Wi
i got the old gas out of the tank and put half gallon of new 93 octane in it, i had to put new gas in it because i just got the carbs cleaned... will that gas i just put in it be good in the next month and half when i start riding? or should i start the sled up every day and let the fuel run through it?
I don't want to end up having to clean the carbs again, i don't want to say i cleaned em too early.
should i siphon the gas out when it gets closer to riding season?
thanks
Yup use double dose of stabil and she'll be just fine,they say 2 years with
double dose, it works too i've done it.
Do NOT start your sled every few days just to run gas through the carbs! I would either leave it or add stabil if your really worried. If you add stabil though run it for a little in order to get the stabilized gas from the tank into the carbs, then just leave it alone!!
93 octane will be fine till the snow flies ..... i have always run 93 and have never had a problem with my carbs
