Henrik
- Sep 29, 2004
Well... I'm really kinda into building a SRX mod but this idea about building a Venture or Phazer (I'm talking like a '91 - '94) mod can't get out of my head. So..
-How much travel did the VMax 600 have?
-How would front VMax600 shocks work with a longtravel SX skid with Ohlins shocks?
-Exciter chaincase DnR, 8-tooth and what track? Would a Pol 136"/1.75" be too much?
-Engine mods??? Needs to be at least somewhat reliable...I'm thinking Mikuni Round or Flatslide (stock carbs felt wierd), reeds, pipe, possibly porting...Big bore? Nah, it's aircooled and I don't think it's a good idea - although it would be making more hp at low revs so...
-SX seat and tank - possible or not?
-Venture hood, Exciter light, loooow wind shield.
-Bars high up in da sky...
Maybe I'm going crazy... Would look cool, would be light...Would it work?
What you want to do is get the 600xt 1996 front and rear....put that in a phaser.
ive got a 99
hey what mods are available for the little phizzer....
i have a 99....
i have a 99....
99, you can do some clutch work on it...8cr w/3.1g inner hole 3.6g outer w-s-w spring with a 45 deg helix. red sec spring at 80....jet to 142.5L & 143.3R
actionjack
There's a 99 phazer tunnel and bulkhead FS on ebay will it take a 700SX or SRX motor easily?
a 700 sx motor should go in ....
Junior
you'll need to add heat exchangers which is an UGLY job
true..very true....
Oyvind Ryeng
Is this also applicable to the 1989 Exciter 570?MrSled said:What you want to do is get the 600xt 1996 front and rear....put that in a phaser.
its more then just the shocks and skid but I would think it would work the same...
