schmidtty
will a 144 track work in 141 skid is there enough adjustment or is there a simple way to make it work like bigger axle wheels thanks
yamahaboy701
There is not enough adjustment, you will need just a small rail extension.
They are a few kits out there to make a 141 to a 144. Here is one:
http://www.hartmaninc.com/144trackkit.html
Mysledblows
You could get away with it if you ran extrovert style drivers and a big wheel. Actually that would work pretty well I think. Might not even need the bigger wheels with a set of extros.
Easiest one to do. You will need an off set axle for big wheel kit. Turn it around backwards. The off-set axle gives you 1 1/2 inch which is half the 3" difference of a 144 vs. 141, just what you need.
Mysledblows
I forgot about the offset axle. That would easily make it up. Funny thing is I'm using them in both my sleds. I'd still do the drivers so that you can loosen up the track and get it to roll freely.
