yamahaboy701
I am rebuilding my primary clutch on my viper with new rollers, pins, bushings, etc. My question is which way do the roller and the weight bolts go? Which side does the nut go on and which side would the bolt go though?
Maybe it does not matter on a yamaha clutch but my P85 I had on my 97 SX you had to have they the right way or they would come lose.
If your looking at the front of the primary the nuts go on the left side, Bolt slide in from the right. Not sure if it really matters,, maybe for balancing...
I always put it back the way I took it apart. Hope this helps..
yamahaboy701
DV8 said:If your looking at the front of the primary the nuts go on the left side, Bolt slide in from the right. Not sure if it really matters,, maybe for balancing...
I always put it back together how I found it but the roller bolts and weight bolts were put in different ways so I was a little confused. LOL
Thanks for the large micro fiche picture the Yamaha OEM parts micro fiche I use was too small to tell from.
