what do u think is the best weight for top end ????
like if you weighed in at about 98 lbs.That would be the best weight and more speed...lol
close to i'm 150 lolllll... but what about primary clutch weight you should be able to anwser that u play alots in your clutch last winter
well...I will be running this season with 8Dn-20 weights.4.5 gram inner and 5.5 gram outer.I have the 15mm rollers in it for now,seem to be good also.I will be using stock primary spring also.In the secondary I am sticking with stock helix and red spring at 70..Going to a 51/43 helix I was over reving a lot.With both my clutches re-built now,everything is new again,should perform pretty good. Not sure if I will play with my Hc's again.I have a spare clutch ,so I may set it up with the HC's or just sell them./
coool ...bad i'm not there to make some test with u ....i got a friend here but now i beat him with heel clicker so he did like a ghost disapears its hard to tune alone u think u are faster but you are slower lollll.. i like to make those try with someone or atleast a radar for top end
Triple X
2000ft radar run, I like the 8dn-00, they have alot of tip mass.
