toolman11k
Just bought a 1998 SRX, pulled the carbs, I think the Jets are wrong, does anyone know for sure what the stock jetting is, both pilots and mains?
Oops forgot the mention it's a 700
waynemags
jetting
let me know what altitude and temps you want to jet for. ill get them for you.toolman11k said:Just bought a 1998 SRX, pulled the carbs, I think the Jets are wrong, does anyone know for sure what the stock jetting is, both pilots and mains?
toolman11k
Not sure of the altitude, just trail riding here in Minnesota.waynemags said:let me know what altitude and temps you want to jet for. ill get them for you.
This has 142.5 in all three so I know someone messed with them.
It has 42.5 Pilots.
waynemags
jets
need average temps at least. can you ball park altitudetoolman11k said:Not sure of the altitude, just trail riding here in Minnesota.
It has 42.5 Pilots.
mopar1rules
pilots are correct. mains should be 146.3 pto/center and 148.8 on mag. this is for sea level.
stock, mj#1,#2;146.3.mj#3;148.8.pj#42.5. jn3.0. ps 1 1/8. you need to adjust for altitude and temp.
98+01srx
I run 145's across the board and i am pretty close to your area. I ran ran 135's on my race sled last winter on the coldest day and never burnt down. I like to run little bigger pilots think both my sleds had 47.5 when i bought them and i switched out to 50's for the extra fuel on the hole shot.
toolman11k
Thanks all, I think I should be able to run the sled with the 142.5's but I will get the stock jets back in there for reliability.98+01srx said:I run 145's across the board and i am pretty close to your area. I ran ran 135's on my race sled last winter on the coldest day and never burnt down. I like to run little bigger pilots think both my sleds had 47.5 when i bought them and i switched out to 50's for the extra fuel on the hole shot.
I always wondered why they ran the MAG side richer since it gets coolant first?
