clutch help
waynemags
alberta canada
hey guys. my 98 700 has a yellow spring in the primary and a black in the secondary. not sure what weights are yet. will these work for agressive trail riding? also have a 600 clutch for parts. it the primary with black spring and weights stamped 08-cr. any idea if these are any good to me for my 700? ill be around 2400 feet. trails and ditch banging.appreciate your help.
The yellow primary is aftermarket. The secondary spring should have either a red; green or silver dot on it but might have worn off. 8cr weights are 100% totally useless for a 700 SRX as they do not weigh any where near enuff to get proper rpm,s. Drive the sled 1st & see what rpm,s are before you make any changes. You may not have to.
