98+01srx
I was told you gain HP by putting Viper CDI on SRX. I asume its because of more timing? Will I gain anything by doing this? I already have a 3 degree advance with a timing key. If this is false where is the difference in the ignitions? Because i also heard Viper's have hotter ignition.
this is for drag racing only, it will destroy your motor on longer pulls.
98+01srx
So what does the box exactly do different? Will it work for 1000' ft
98+01srx said:I was told you gain HP by putting Viper CDI on SRX. I asume its because of more timing? Will I gain anything by doing this? I already have a 3 degree advance with a timing key. If this is false where is the difference in the ignitions? Because i also heard Viper's have hotter ignition.
Care to give me more info about this?
valin
The timing curve is different. It also would opens the valves sooner.
98+01srx
is this the one need 8EK-85540-00-00?
shortstop20
- Mar 6, 2005
- Stickney, South Dakota
- www.snowmobilefanatics.net
Viper has some VERY hot timing in the midrange.
mopar1rules
98+01srx, did you ever try the 8EK box on your '01 srx?
