mopar1rules
anybody play around w/either of these softwares?
http://www.tsrsoftware.com/
http://www.bimotion.se/
mopar1rules
c'mon...somebody's got to be playing around with something.
It's stock
FuzzButt
I could use help with a 2 stroke outboard making more power but I've never seen software available to help with that.
mopar1rules
lets say you want to play with your head profile to make a little more power. you input your bore, stroke, max hp @ rpm, etc.....and then it will output data for a head design....it will tell you what to have then, as far as squish, band width, band ratio, trapped volume, etc. this is if you are using the tsr program...squish and compress. you can then tune your engine for more power. but if you put crap in, you get crap out. so, you need to feed it accurate info from the start. i was talking w/a few other individuals and one told me he like the tsr better than the bimotion, and the other said that both are good, both take a little bit of different input to get the same outcome, and that the bimotion is a little more complicated than the tsr.
i found out that bimotion gives you the upgrades for free and that tsr makes you buy the upgrades for like $20.
