PJVMAX
- May 5, 2003
Need a new primary spring for my '01 SXR 700, the original broke at the end of last season. I am clutched per the tech page and was wondering if there is a better spring to run than the stock spring. I had a tendency to over rev last year even though I had the weights full loaded.
what kit from the tech page are you running??
Wut spring ya runnin? It depends on how much overrrev you have but going to a spring with the same preload & less total force will bring down rpm,s right thru the whole shift.
PJVMAX
- May 5, 2003
Turk said:Wut spring ya runnin? It depends on how much overrrev you have but going to a spring with the same preload & less total force will bring down rpm,s right thru the whole shift.
I'm running the stock primary spring per the instructions on the tech page for clutching a '01 SXR 700. 51/43 helix, stock spring, 4.5g in both holes, 2 engagement shims, 14.5mm rollers.
