shavedheadedyamaha
ok im going to do new rings and was wondering what to "clean up" or it porting it easy???... i was just thinking or smoothing out the ports intake and exaust.. but the cylinders are nic a sealed right? if the r then i just have to stay off the rim of the port right... any help would be great
mopar1rules
yes, they are nicasiled. if you want it ported, pm me.
blueracer
shavedheadedyamaha said:ok im going to do new rings and was wondering what to "clean up" or it porting it easy???... i was just thinking or smoothing out the ports intake and exaust.. but the cylinders are nic a sealed right? if the r then i just have to stay off the rim of the port right... any help would be great
if you want it ported the correct way, get in touch with mrviper700
regert
don't pm me, I only know how to over heat them or blow up the re-coil some how....LOL....
Porting is very beneficial on srx's. I would suggest having an experienced professional perform the work. Either get in contact with Mrviper, Or Iantomasi racing! Which ever is closer to you.
Skidooslayer687
Dons work (mrviper700) is second to none, he did mine last year and I am Very impressed with how it worked. Contact him and he'll fill you in on the details
turbor
yup don's work an knowlege of the srx's is second to none
Triple X
Who is this "None" guy?....lol
shavedheadedyamaha
did you have to re jet and re clutch?
turbor
You have to discuss this with the guy who does the porting, different porting specs will require different jets specs! Send a Pm to mrviper(don) he will answer all your questions!
