Rambunctious
if adding viper shocks to my 2000 srx, what is needed for limiter strap
can the stock one work since i read we should pull the straps up to reduce hyfax wear on stock setup, or do i need longer strap to go with viper shocks.
please reply
thanks
Ramb
please reply
thanks
Ramb
Just make another hole in the strap ...should be long enuff as long as you don,t need to lengthen them a lot.
2000 srx limiter straps are extremely long anyway...would be fine but you might have to change the spacers in the control rods ....smaller on the bottom.
Rambunctious
thanks
smaller on the bottom why? because there is more travel with the vipers so you don't want too early of a coupling. or becaue there is more initial set in.
and you want to re-center the gaps with your weight on the sled.
thanks
ramb
thanks
ramb
by going smaller it well let the suspensions come out further and give you the travel you need.
