skiddo sc10 3 into a viper, measurements needed
maxwell
Victoria, MN
I did a search on dootalk and on here, and I am unable to find the measurements. I am installing a sc10 3 (sc10 III) from a MXZ into my viper and need the measurements. The skid is out of a 2002 MXZ.
I had a post on dootalk myself with these measurements a few years ago. It was under the Formula forum. There are a number of guys on there that would know off the top of there heads. It is a 2 point moun, so all you need it the distance from the axle and the the distance between the 2 mounts. Adjust the rest of the orientation to get the alignment you want with the Viper.
There are a few on here that have done this swap as well. There should be some posts that you can search for.
