Viper Clutch engages 3750. Is that Bad?
ryanryan
Southern Ontario, Canada
I fired up the Viper today and the clutch was engaging around 3750, and the manual says 3000, is this bad or nothing to worry about, will it change? I just put the belt on and I did it properly and I put it in the right direction and everything, will it just get worked in? Also, the track was loose still, I don't know if that matters or not?
Your manual is wrong. stock engagement is supposed to be 3900 rpm.
Yamidude59 said:
Yea but you got upgrades to your clutch^^^^
3000 seems low, but my srx calls for about 3800
Yeah I was just trying to prove a point that it doesn't have to be right on factory spec!
