Apex handle bars on viper?
Yup
Yes, I run them on my 04 viper. They are great. Just a note for you......if you want to do it and you have an 02 or 03 viper then you will need to get a 04 or RX-1 throttle block and a new two into one (split) throttle/oiler cable to do this since you can't get the one piece throttle block on the apex bars due to the bend at the end.......not to mention if you tried to take off the grips you'd probably trach them. The 04 and RX-1 throttle blocks are two piece.
Madmatt
