Twin Pipes on my 96 vmax 600 (Jets?)
The Dish
madison
Hi Everybody, I have twin pipes on my 96 V-max the yamaha gyt pipe. The jets are all the stock. Looking at my plugs it seems to be running on the rich side, surprisingly. My question is- does anyone know what Yamaha recommends running for jets with the twin pipe?
Thank you,
The Dish
This is everything you need to know...
http://www.totallyamaha.net/forums/showthread.php?t=19595
Nozzles will be different for the 94,95's vs the 96's because the 96's came set up differently.
If you have a '94 or '95 you need to use Q8 nozzles, '96s already had them in there. The spec sheets say to use them in only the LH carb, my Yamaha dealer said that there was a later bulletin that called for them in both RH and LH carbs. So, for myself, I put the Q8s in both just to be on the safe side.
