Adjustable TSS Struts 96 Vmax Swap
BigMan76
Chicago SW 'Burbs
Couple of questions and thought I should post here:
1) I was able to get the adjustable TSS Struts off of a '96 Vmax XTC. I have a '96 Phazer II; can I swap out the stock Phazer struts for the XTC struts or will it require any modifications?
2) I also acquired another set of VMax struts (possibly 94-96; they are not the XTC adjustable version) without all the accompanying hardware (only the struts-no knuckles, absorbers, etc.); will these accept the same additional hardware as the '96 VMax XTC?
3) Does anyone know if I perform the swap (install '96 Vmax TSS struts and take off Phazer II struts), can I then reuse any of the hardware (knuckles, clips, etc.) from the Phazer II for the second set of Vmax struts (non-adjustable)?
Any help would be greatly appreciated!
thanks.
This all stems from the following post:
1990 Exciter Transformation ! ! !
http://www.totallyamaha.net/forums/showthread.php?t=22988&page=1&pp=10
thanks.
I believe the part # on the GYT struts is Yamaha part # SMA-8CA91-10-00; I only have the struts. Does anyone know the part #s or model year sled that I can use for parts to get the knuckles, absorbers, etc.?
Thanks.
I have been looking at some of the fiche sections at one of the dealer sites but cannot find the part # for the adjustable tss top rubber cover; any ideas?
They are shown in the bumper section: 8AY-77554-01-00 PROTECTOR 4
they should fit absolutley fine without issue. i installed them on my 89 exciter, it literally took me about 20 minutes to do both sides.
